Old 03-07-2022, 10:54 AM   #7
Lowski
Originally Posted by Frodo View Post
(1) Seems like the bike, as mounted, juts way to the passenger side (as opposed to being more or less centered). Probably not a huge issue...I guess you just kinda have to keep that in mind if/when passing someone, eh?
(2) You ever get pulled over for having no readable tag when you have this mounted with a bike in place?
With the 1-Up rack you can skew the bike one way or another depending on where you set the arms that hook over the tires. I think the photo angle is deceiving here. Either way the bike doesn’t extend past the mirrors on either side of the car.
I haven’t used the rack a ton, but I haven’t been pulled over for it or my driving habits. I figure it’s worth the risk as I only put the rack on when I know I will have a bike with me. On my Subaru I drive around all summer with the a Yakima hitch rack that blocks the plate when it’s in the flipped up position. I’ve never had problems with that either.
Originally Posted by robdelorenzo View Post
Where is the rear tow hook located? I am ashamed to admit that my car has only been winched onto a flatbed from the front.
The rear tow hook is centered in the impact beam directly behind the rear license plate. To do the mod I scooted it to the right a few inches, but still hidden behind the plate.
Originally Posted by imhighlander View Post
If you're relying only on the expansion ball in the 1-Up hitch, are you not concerned that it could loosen and leave your bike on the road behind you?
The 1-up rack I have doesn’t have an option for a hitch pin, so the expander ball is the only retention option. I do worry a little about the rack pulling out as I have found that the ball can loosen over time. If not caught in a timely manner it may work itself out of the hitch. I periodically check the rack and tighten as needed. On the Boxster I check every time I put a bike on since the receiver tube isn’t as deep and the bike is more exposed to the wind as compared to a taller vehicle like an SUV.
Lowski is offline   Reply With Quote
