Old 02-24-2022, 07:12 PM   #18
Tweetdriver63
Looks like you changed the design some. Having the cup holder go into a slotted hole will be better then original design.
You going to have something for the cup/bottle to sit on at the bottom?
Still think the part at the L is going to be your weakest point. Instead of it being a square on that inside corner, make it an inside filet (sp?) Will give it more strength.
I also did a slight redesign of the bottom supports.
What do you think?
Tweetdriver63 is offline   Reply With Quote
