Old 02-24-2022, 05:38 PM   #21
Tweetdriver63
Originally Posted by elav View Post
I've only fixed one door so far but it is my understanding that if you open the outside door latch and the window moves down, the micro switch for the outside door handle is working. If you open the door with the inside door handle and the window moves down, the micro switch in the inside door handle is working. If your window doesn't stay down while the door is open, your door lock mechanism micro switch and/or cam in this mechanism is bad and needs to be replaced. I hope this helps and please confirm any part numbers before ordering as I believe the door lock mechanism can change based on type of security system your car has, etc.
What's the diagnosis if the (driver's side) window doesn't move when you pull either the outside or inside handle, but you can hear something working like it's trying to, and the auto up/down works perfectly when you operate the convertible top.
When I give a short pull (maybe 1/2 inch) on either the inside or outside handle, I can hear -- maybe even feel -- something move, and then hear/feel it move back when I let the handle back in. However, the window glass doesn't move at all.
As it is right now, I just always have to push down slightly on the top of the window before I close the door.
Tweetdriver63 is offline   Reply With Quote
