Old 02-24-2022, 11:45 AM   #12
Tweetdriver63
Sorry if I'm rehashing.
I've read through this thread at least twice.
When my driver's door is closed and the window up (obviously), a little pull on either the inside or the outside handle and I can hear something move/try to move. Release the handle and I can hear it reverse. I think I can even feel something moving. However, there is zero movement of the window glass.
I just want to confirm this is a problem with the door latch? I don't think it's any of the microswitches, since I can hear/feel it trying to do as it should when pulling or releasing both handles.
As I'm sure most of you know, when opening the door, it isn't really a problem if the glass doesn't drop at all. It's only when closing it that it's a issue. I've been living with it by just remembering to push down slightly on the glass as I get in/out of the car so that it will be down a little when I close the door. The window always goes back up once the door is closed.
Tweetdriver63 is offline   Reply With Quote
