Old 02-23-2022, 05:38 PM   #6
Gilles
Originally Posted by robdelorenzo View Post
Does anyone who has had wheel spacers on for any length of time care to chime in with their experience? Thanks.
Rob, the wear will be on the wheel bearings as you would be increasing the load on them, these are not to expensive but are a bear to remove from the hubs..
The longer lug nuts are to compensate the extra thickness of the spacers (as you need to have a minimum amount of threads to be safe), usually the companies that sell the spacers also offer the longer lug nuts.
However, when my 987 died I remove the spacers (7mm and 15mm) and put them on the 981, because they just look great
Gilles is offline   Reply With Quote
