02-23-2022, 11:37 AM
#22
Originally Posted by Stl-986
try rotating the piece 45 deg & standing it up vertical to print. Should be able to print that as a single piece even with an Ender 3. May need need supports, but most likely not.
For ABS 20% infill should be more then good enough but I wouldn't go higher then 40%
Is this how you meant?
https://www.thingiverse.com/thing:5260159
