Old 02-19-2022, 02:01 PM   #13
suburban99
Ok here's where I am at now.
Adjusted cable as described still no park.
Disassembled again to get at the Range switch.(it's new)
Removed switch from transmission. Attached leads of multimeter to GND and Pin 8 of tiptronic plug in rear trunk No continuity...Pulled off range switch and carefully rotated the inner splines and yes I have continuity to Tiptronic plug. Assume wiring is OK.
Pulled rearward on transmission lever with a crescent wrench and tried to spin wheels. They spin. Assume parking pawl or linkage is pooched..Basically not going into park, because wheels don't lock up. Off with the pan?
suburban99 is offline   Reply With Quote
