Old 02-19-2022, 07:59 AM   #10
suburban99
When I check the tiptronic connector in trunk:
Terminal 36---gnd should have continuity when trans in park, I do not.
I have the shifter cable disconnected at the shifter and push cable all the way in and still get R when tested for continuity at the tiptronic connector.
Their seems to be no adjustment on the range sensor as it is dowel pinned.
What am I missing?
Does the shifter need to be connected to the cable to "push" the switch to signal park?
suburban99 is offline   Reply With Quote
