Old 02-16-2022, 12:57 PM   #3
Gilles
The CV's are not the issue. The bolts torque values are not that high as the bolts are small (29 ft. lbs on the M8 bolts). If a thread locker is not used, they will come loose; it is as simple as that.
Also it would be a good idea to clean the treads on the hubs with brake cleaner prior of applying the Locktite
Gilles is offline   Reply With Quote
