Old 02-04-2022, 10:21 AM   #1
kbod
A major clue I see when reading your post is:
"When filling with fuel the car does not start without mashing the pedal while cranking"
So on a modern day car "mashing the pedal (throttle) just gives the engine more air.
The DME/ECU gives the engine gas.
So your fuel air mixture is to fuel rich after fueling so it will not start until you give it more air by "Mashing the Pedal"
So my guess is that you have an issue with the EVAP system. bad purge valve or the like. An EVAP purge valve stuck in the open position allows fuel vapors back into the intake. So it causes a to fuel rich situation after filling up.
EVAP systems can be a PITA.
Your stalling when coming to a stop can be caused by this same situation.
or.... a vacuum leak.
Have you done a vacuum test with a proper vacuum gauge???
First id like to thank you on how helpful you have been ever since I bought this Boxster, now for the evap system, I took off the passenger fender liner and replaced the 2 solenoids along with the charcoal canister, so for the evap system that leaves the lines themselves along with the solenoid under the intake manifold. I suppose my next move is to first do a smoke test to see if there are any post MAF vacuum leaks, then if nothing obvious shows its to test the evap valve under the throttle and presumably replace those. While the little vacuum hoses have all been replaced the vacuum canister and solenoids haven't so those might be an issue. I was also considering the possibility of a leaky injector? but that would probably throw a MIL
kbod is offline   Reply With Quote
