Old 02-03-2022, 04:15 PM   #1
blue62
Originally Posted by kbod View Post
2001 Boxster, 116,000 miles. I bought this car with a p1341 code for bank 1 variocam solenoid, I swapped it with a used unit and it kept throwing the code and running like crap. Changed the air oil separator, cleaned throttle body, and tried correcting the timing and no matter what the car wouldnt run right. After dropping the complete engine and replacing the variocam solenoid again with a 1400$ oem porsche unit, replaced the ims bearing with the LN engineering upgrade replaced all the cam cover seals and camshaft wear pads. changed the rms and all the seals, put another brand new AOS on (oem) changed the vaccum lines and hoses for the brake booster, replaced the fuel filter aswell. after putting in new fluids and everything the car runs pretty good. theres a slight ticking sound on cold starts, but no more check engine light or stalling after coming to a stop. Heres the issue now. The car still has a significant idle drop when coming to a stop and almost stalls, also when filling with fuel the car does not start without mashing the pedal while cranking and has strange issues like that. lastly the car has a rough idle where the engine vibrates a lot, fuel economy is meh 15mpgish. I replaced the charcoal canister and solenoids next to the canister and it still has the issue. as of right now there are no codes anymore, although I cant pass smog since the Secondary air injection and evaporative monitors wont say ready despite driving alot. any help or advice to fix the idle and monitors would be greatly appreciated!
A major clue I see when reading your post is:
"When filling with fuel the car does not start without mashing the pedal while cranking"
So on a modern day car "mashing the pedal (throttle) just gives the engine more air.
The DME/ECU gives the engine gas.
So your fuel air mixture is to fuel rich after fueling so it will not start until you give it more air by "Mashing the Pedal"
So my guess is that you have an issue with the EVAP system. bad purge valve or the like. An EVAP purge valve stuck in the open position allows fuel vapors back into the intake. So it causes a to fuel rich situation after filling up.
EVAP systems can be a PITA.
Your stalling when coming to a stop can be caused by this same situation.
or.... a vacuum leak.
Have you done a vacuum test with a proper vacuum gauge???
