Old 01-26-2022, 04:56 AM   #1
CrisZenithBlue
CrisZenithBlue's Avatar
Originally Posted by 986lp View Post
Vetman, what I did was stick a flathead screwdriver in the gap between the arm and ball joint and twist to pop it off. To get them back on, I did use a prying action with the tool provided in the toolkit.
CrisZenithBlue, I discovered that the brass retaining nuts in the windshield header split causing the latch holder to tilt slightly to the back when under tension. I stuck some rivet nuts up there and now the top closes properly. But it's really tight. I know those brass retaining nuts are known to be weak, I do think the tightness of the top caused them to fail.
I'm hesitant to start adjusting for fear that I mess up a top that essentially works. What makes me nervous is that my top operates slower than the 12 seconds people cite and the motor right before finishing dropping or raising the top makes this straining noise for 2 seconds that's worrisome.
I had those same nuts failing but for other reasons and following some really good instructions on this forum i was able to put new rivet nuts and made it nice and tight again, glad that made the top sit right for you.
As for the top noise, i think the noise might be normal, my top motor makes all kinds of noises depending on where it's at in the process. You should put a dab of grease on the rails where the top moves on, that helps the motor a lot and can prevent top transmissions to fail in the future. If it works i wouldnt mess with it for now. If it does break at some point, for whatever reason, rest assured you can fix it fairly cheaply with some help from the forum, most of us have been there.
CrisZenithBlue is offline   Reply With Quote
