Old 01-18-2022, 12:43 PM   #1
Quadcammer
Originally Posted by aussieboxy View Post
Can I replace the outer CV boot without removing the driveshaft completely? I’m thinking of removing the shaft from the gearbox, removing the CV & boot to get access to the outer CV Boot.
Is there an easier way to do it?
done it this way, but its not ideal. remove the axle nut, spray some penetrating fluid in the splines, and hope it comes out.
When I later did wheel bearings, my axles came out no problem, so if I had to do it again, axles are definitely coming out.
