I just did the mirror repair, google 986 mirror removal theres several youtube videos. Theres a plastic mount behind that breaks when the mirror is hit from back to front. I JB Welded and it and clamped worked perfectly. Another hint the top mounting screw under the weather stripping I used a finger cut off a nitril glove with a small hole in the end for the screw to go thru and an extention with torx bit so the screw cant fall in the door. Tighten the mounting screw then just pull the glove out.
Dave
1998 Boxster
1978 R100RS BMW Motorcycle 140K, 1 owner
