Old 11-16-2021, 03:12 PM   #2
blue62
Originally Posted by Beelzy View Post
Thanks for the response.
Replaced battery 800 miles ago
Automatic transmission, and other throttle response in gear.
Nothing done recently except the battery.
If I understand your last post you have throttle response in forward gears...is that correct???
Whenever you disconnect your battery or have a dead battery you need to re-adapt
your E-gas (gas pedal). If you didn't re-adapt your E-gas pedal it could be the problem.
To re-adapt the e-gas park the car on a level surface.
Disconnect the battery for a few minutes.
Reconnect the battery.
Turn the key to the on position for at least 60 seconds. Do not start the car.
Do not touch the gas pedal.
Turn key to off position for at least 10 seconds.
Then start car and see if it fixed your issue.
