Thread: Lowering a 986
Old 11-09-2021, 10:40 AM   #2
986 Boxster
986 Boxster's Avatar
Maybe they should make this a sticky.
Bilstein B4 - Replacement struts for non sport suspension. There's a few B4 variations depending on the vehicles manufacturer, but these are all intended to replace the standard struts fitted when the car was new WITHOUT THE SPORT SUSPENSION.
Bilstein B6 - A non adjustable sport strut . The B6 struts are designed for someone that wants a sporty ride without lowering the car or changing the original springs.
Bilstein B8 - Just like the B6 struts but shorter. These are only to be used with lowering springs or for vehicles with the factory sports suspension. They are shorter to ensure the all important coil spring pre load as lowering springs are shorter than OE springs.
Bilstein B12 Sportline - Contains 4 x Bilstein B8 struts and Eibach Sportline lowering springs. This kit is non adjustable with typical lowering of up to 50mm and are a much harsher ride than the B12 Pro-Kit.
Bilstein B12 Pro-kit - Contains 4 x Bilstein B8 struts and Eibach Pro kit lowering springs. Typical lowering 30-40mm to give the perfect balance between looks and performance. This kit is also non adjustable.
Bilstein B14 (PSS) - A height adjustable coil over kit with lowering between 30-50mm front and rear to fine tune your look.
Bilstein B16 (PSS10) - A fully adjustable coil over kit. Lowering up to 30-50mm and 10 pressure adjustments. This kit allows quick and easy parallel adjustment of bump and rebound with a twist of a dial. Flexibility for road use or track.
Bilstein ClubSport - The ultimate kit. Complete flexibility allowing 100 setting variations. You can easily adjust the bump and rebound separately to fine tune your kit to any track.
This kit can be used on the road but is better suited for the track.
986 Boxster is offline   Reply With Quote
