Old 11-03-2021, 01:01 PM   #4
PaulE
That's a nice upgrade for Litronics, I didn't realize that the reflector bowls for the projectors get corroded over time which affects their brightness. Adding a relay to the halogen high beam, so that it only operates when pulling the stalk to flash high beams when the lights are turned off, would be a nice addition. The bi-xenon high beam is more than adequate when the headlights are turned on, the halogens high beams only add heat when the headlights are turned on and you need high beams.
