Old 10-22-2021, 07:02 AM   #1
BruceH
BruceH's Avatar
Bruce... be sure to post the before/after shots.
Unfortunately these lights are unusable in my opinion. There is heat/melting damage between the brake light and reverse compartments. When you press the brake pedal, it lights up the reverse (bright white) compartment as well due to the holes. The right side is worse than the left. There is no way you could pass a state inspection with these. I have tried PMing the seller several times with no response
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
