I've had something similar happen after disconnecting the battery for maintenance, it was pretty shocking to see my 986 suddenly had 0 miles on it. It's happened to a few other people if you hunt through old posts.
If I recall correctly the fix is to disconnect the battery, insert the key and turn it to the first position, then reconnect the battery. I have no idea why it works, but it does fix it. Alternately, disconnect the battery and wait a few minutes, repeat, until it reverts back to the correct mileage.
