Old 10-05-2021, 08:15 PM   #13
TTGator
As far as checking Camshaft Deviation it is simple:
Take the car for a good spirited 20-30 minute drive.
You want the engine oil good and warmed up and at a stable temp.
Hook up the Durametric and go to the actual values tab.
Click on... Camshaft deviation Bank-1
Click on Camshaft deviation Bank-2
Should bring up a graph and also number on the right hand side.
Do this at idle RPM.
Do a search here on the forum for camshaft deviation you will find plenty of screen shots.
If you have any problems figuring it out let me know.
Just noticed that you have a 2003 so I think your Vario Cam system is different. If it is the Vario Cam plus system then that system functions in a different way. So I do not know if Camshaft Deviation applys to that system. Perhaps someone here on the forum knows.
Or watch the video
Only inconsistency I see is I was told to do this from a cold engine and you are saying warm.
1998 Boxster
2015 BMW M4 Dinan Stage 3
2016 BMW S1000XR
2015 Ninja 300
TTGator is offline   Reply With Quote
