Old 10-04-2021, 03:49 AM   #1
Radman
Originally Posted by rexcramer View Post
I would suggest opening the top and look down inside to see how much debris is in there first. Vacuum the big stuff out, then test the drains with a cup of water to see if they run clear. If they back up, then you need to fix that first. Follow the YT link; https://www.youtube.com/watch?v=Hz-C9pkMnDk
Otherwise, wash the rest of the car normally and sponge bath those two areas until you sort it out?
Agree with this. Make sure the drains are clear first. Easy to check.
Radman is offline   Reply With Quote
