Old 10-03-2021, 10:55 AM   #1
chromecarz00
Originally Posted by 986 Boxster View Post
It could be a lot of things. The vibration could be from your tires, how old are your tires? Wheels, have you hit any curbs lately?, it could be drive shaft vibration, etc. Creaking is worn out struts or mounts. If your tires are fairly new and wheels are straight, from what you are describing with your high speed wobbling your struts are most likely your problem. It looks like you need a suspension refresh but your looking for a simple solution, Good luck
Thanks for the reply.
Tires are about 1 year old, 10k miles.
Wheels - not really, and the issues have stemmed from awhile to be honest.
I would guess mounts in the back but struts being fine, and needing both in front. I am confused that the tech that I had do the bounce test didn't say immediately that I need new ones. They don't seem to be leaking either.
Appreciate the response, I'll see if I can diagnose a bit further...
Thoughts on the clunking?
chromecarz00 is offline   Reply With Quote
