Old 09-28-2021, 07:26 PM   #19
Silber
Originally Posted by ike84 View Post
...Without it, none of the other stuff will save your engine when you throw on slicks and go balls out on a long right hand sweeper.
Thanks for the great reply, Will read up more about the X-51 mods. The oiling issues on this engine are certainly not ideal by any stretch of the imagination
Planning only autocross, no track time. Autocross "sweepers" are pretty short, If I get a deep enough sump I should be able to ride out any that I run into. At least that is my thinking at this moment. The Accusump seems limited, it sounds like if you run it with the solenoid it is too slow, if you run it wide open you can overload the system with oil possibly.
That being said, I will almost surely be running A7's so I could conceivably pull enough G's to really have an issue. I don't want to find out a deep sump wasn't enough the expensive way.
regards,
Silber
2002 Boxster S - Silver/Boxster Red
Coilovers - LSD - CAI - High Flow exh. - F&R Adjustable Sways
LN 3.2 to 3.8 - parts acquired, pending assembly and tuning
Silber is offline   Reply With Quote
