Old 09-16-2021, 07:37 AM   #11
ike84
Originally Posted by Silber View Post
You might be right, I don’t think it will hurt anything to make sure that the intake seals completely.
However, Something caused #2 to self destruct. The spark plug got so hot only on that cylinder such that the boot partially melted and stuck to it.
That much heat is usually caused by overly lean, caused by too much air or not enough fuel, or a combination of the two.
I already bought 6 new injectors, so covered not enough fuel. Making sure the intake seals should cover too much air. Think that should keep the new motor from suffering the same fate, any thoughts?
Regards,
Steve
This isn't entirely accurate. Lean burns do not cause excess heat. Lean burns can cause detonation, which forces the flame wave in unitended directions and consequently cause certain areas to run hot. Lean burning by itself, however, runs cool. If you don't believe me, grab a blow torch and max out the flame. Then start turning down the fuel knob and see what happens. A more objective proof of this lies in aerospace applications, where pilots have relied for many decades on cht and egt readings to monitor their engine status. Any pilot who understands these number will back up what I am saying here.
Sent from my SM-G970U1 using Tapatalk
