Old 08-30-2021, 05:45 AM   #17
Starter986
1998 Boxster Silver/Red
Originally Posted by pilot4fn View Post
I had this weekend a small leak pretty much in same location as the OP has, showing mostly at the under the front of the engine bellypan. Also a small amount of water dripped little more forward (maybe under the seats location) as I was racing at the track.
Had to retire before last two starts and took the car home driving it... while keeping cabin heater on HOT sertting and selecting only highway roads to allow coolant to stay relateively cool - I have a low temp thermostat.
No leaks on the way home for 110km and temp stayed low.
Opened the bellypan under the engine and found out the leak coming from water temperature sensor, but only when the water was at normal or higher operating temperature and the water pressure was high.
You do know the low temp therm has absolutely nothing to do with how hot/cool your engine runs, right?
Have you considered snuging up the temp sensor?
1998 Porsche Boxster
