Old 08-29-2021, 02:21 PM   #1
piper6909
piper6909's Avatar
Originally Posted by vkmotorsports View Post
Thank you piper6909.
1) When you say "water pump" is that the same as "coolant pump" in the Bentley manual ?
2) Is the "shaft seal" same as "crankshaft seal" ? that repair work is beyond my capability at the moment.
What would the approximate cost of repair be for this at an independent repair shop ?
Yes to 1, no to 2.
Sorry if I wasn't clear. The coolant pump (water pump, as it's often called) has a seal around the pulley shaft. It is not a replacable item, though. You'd have to replace the entire pump.
I suspect that's where your leak is coming from. If you haven't done so already, remove the belly pans like stl-986 wrote, and take a look aroung the water pump to be sure.
Or you can probably remove the cover behind the seats and look from there, but I believe you'll get a better angle from underneath.
2010 Subaru Forester
