Old 08-25-2021, 07:40 AM   #1
Starter986
1998 Boxster Silver/Red
Originally Posted by Oldcarguy View Post
All main and secondary paved roads, no dirt roads or chicken ranches . We do have a lot of leaves in the fall. This size mesh only has an open area of 77% and I’m not willing to use anything more restrictive. At least I didn’t find cigarette butts and bird feathers this time. Also, the mesh does protect against rock damage
It must be the leaves. We've none, per se, in the high desert. I suppose if I was running over leaves most of the time I'be be in the same boat.
Yes... the rocks. That's the primary reason I installed the mesh. Further, I believe it makes the front end look more uniform. Never have a been a fan of those two big holes on the front end.
By the way... from where did you source your mesh? Thanks!
1998 Porsche Boxster
