Old 11-02-2006, 06:03 PM   #23
JackG
Originally Posted by MNBoxster
Whatever... if you must know, I have had my car up numerous times (maybe more than you from the sound of it if that matters) using the Rear Axle Support to raise the car with a Floor Jack to get the stands under it, with several Oil Changes, Plugs change, Brake Fluid Changes, and a Tip S Fluid, Filter and Gasket change...
Happy Motoring!... Jim'99
Jesus, Jim... you don't always have to have the last word.
And I didn't ask, so I didn't need to know. But it sure seems strange that, with all the times you say you've had you car in the air and have been under it, you still didn't know that there are those two totally different points that look similar but serve a totally different function. In fact, you said there was only one. "There is only one 'U' shaped (sort of) cross member under the car, and it is clearly shown in both pics."
Oh well... nobody's perfect.
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
