Old 08-08-2021, 04:36 PM   #16
mikehkang
It is possible. You dont need to remove it, but make sure it is loose. You do need to remove the crossover tubes though
Are the both manifolds easy to loosen and reattach? I read somewhere about manifold seals or sealant. I am not sure I have the skill set to loosen and reattach. I am leaning towards the idea of silicon or rubber hose 'extension' to I can drive the car to the mechanic. At least that will save me the towing.
Thank you Stl-986.
mikehkang is offline   Reply With Quote
