Old 11-02-2006, 09:48 AM   #18
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by MNBoxster
Hi,
Jack, I just came in from crawling under my car and you are right, I was wrong. These are indeed 2 different areas, though they looked the same to me. I have always used the Box Beam 'U' shaped crossmember whern raising the car to set my stands at the jack plates as described in the Bentley Manual.
After a thorough inspection, if you're only raising the car to place the stands under it, I suspect that this incorrect jack point will also work. This piece is a fairly substantial 'U' shaped I Beam and I believe it would carry the weight. Clearly this is what the Rainy Day pic shows.
My choice would still be to use the crossmember which is forward to the one in the Rainy Day pic, because I think the crossmember is better situated under most of the rear weight. But, I think the other would work as well.
One final thing, I would never use either of these lift points for anything other than raising the car to place proper stands in the proper locations...
Happy Motoring... Jim'99
FWIW, I raised my car a couple of weeks ago at the point shown on the Rainy Day site to get the car on jackstands, and had no ill effects.
