Old 07-18-2021, 06:26 AM   #11
Stl-986
To catch up this mornings work.
Using the 03 as a test I disconnected the check valve at the intake and put the gauge in the hole. Got 14hg. Doing the exact same thing on the 00 I get 8hg. This is using the mity vac pump which has a gauge on it, that might not be all that accurate, but at least it does show how much of a difference there is at idle between the 2 doing the exact same results.
The 03 has ZERO issues and runs wonderful so I know that it is good to compare against.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
