Old 07-17-2021, 07:56 PM   #1
piper6909
piper6909's Avatar
Originally Posted by PaulE View Post
I don't know if it's physically possible, or for that matter advisable on the Boxster. But back in the day we would spray some starter fluid around the intake manifold gasket area on the old British sports cars. If the idle speed increased that was a sign of a vaccum leak at the gasket. But cars were much simpler then, maybe this isn't a good idea on a modern car if you can even get to spray in that area.
Better and much safer than starter fluid is propane. While both can accidently ignite with a spark, with propane you'll just light the torch, which you can quickly pull back and away. With starter fluid, you ignite everything that the liquid was sprayed onto.
Take a propane torch (open but not lit, of course) and run it along everything on the bank1 side of the intake.
2010 Subaru Forester
piper6909 is online now   Reply With Quote
