Thanks again for the responses. The smoke is bluish and is oil. In regards to the spark plug check: yes the plugs do look rather fouled. I plan on replacing those when I do the spark plug tubes seals. So, the plan right now is to order an OEM air oil separator, install that, clean out the intake system and give it another go. Thanks again. Your comments and suggestions have been super-helpful. I think the old AOS was failing. I think the brand new aftermarket one failed completely!
Scott
