Old 06-30-2021, 12:14 PM   #14
Quadcammer
Originally Posted by bcrdukes View Post
I ended up with a Tarett Engineering GT3 front sway bar and Elephant Racing adjustable end links.
I'm planning to tackle the job myself in my garage - anything I should know before getting knee deep in this? There aren't very many articles on how to remove the existing front sway bar and vice versa. Thanks in advance.
its very simple. from memory, you need to remove the braces under the gas tank, and potentially loosen the plates into which the thrust arm bolts, but I could be wrong on that. Its a very easy job compared to a 987, no need to lower subframe.
