Old 06-28-2021, 12:24 PM   #1
Jasper7821
Jasper, out of curiosity did you replaced the wheel bearing on the new hub..?
The first time I replaced my rear wheel bearings, I installed them backwards (..!) and the magnetic strip was at the wrong side of the hub and as soon as I took the car for a test drive, the ABS failure light was On..
The wheel bearing on the used hub was installed correctly.
I talked to Pelican and was thinking of buying the Duramatic and they said probably wouldn't do anything in this case.
Jasper7821 is offline   Reply With Quote
