Old 06-28-2021, 04:45 AM   #11
Radman
Originally Posted by pharaohjb View Post
If it pops up again, one trick to diagnosing the misfire would be to swap the coil pack with the coil pack from another cylinder. If the error code follows the coil pack, you know it's the pack, and not something else.
Yep, that was the plan. The CEL only happened once, but the engine had been rough at idle since purchase.
In other news, my attempt at replacing the instrument cluster LED backlight bulbs with LED's has been a failure lol! I ordered a 5 pack of the regular ones and they should be here end of this week or beginning of next. Thankfully removing the dash cluster isn't hard at all.
Also ordered side mirror trim piece replacements as both of mine came broken. I also ordered a 12v outlet replacement so it will fit US spec devices. I use it to hold and charge my phone until I replace the HU.
Radman is offline   Reply With Quote
