Old 06-24-2021, 01:40 PM   #15
dragonflyoh
Please help with connecting to the relay
If I understand this correctly I use a fuse tap for Fuse #7 and run a wire to a pin on relay 12.
You wrote that you used a female spade connector, opened it up, widened the slot so the relay leg would fit through it and cut the excess off the sides. Slid the fuse leg though the slot and put the relay back in.
What slot did you widen? What sides did you cut the excess off of? Maybe a photo?
Thanks!
dragonflyoh is offline   Reply With Quote
