Old 06-24-2021, 08:17 AM   #2
Jasper7821
Yes, it will work, but as you have loosened the upper bolts (unnecessary) you will need to have the car aligned. Next time, just use the strap and you will be fine.
Thank you, I'll try and hope it works. And I planned on an alignment anyways as I had to replace the subframe, hub carrier, strut, axle, and all the control arms.
Jasper7821 is offline   Reply With Quote
