If you are meaning the car doesn't shut off when you turn the key to the off position, then you have a bad ignition switch....which is VERY common. If this is the case, replace it.
What Rob is referring to is accessory retention, which is designed in almost every modern car.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
