Old 06-12-2021, 03:19 PM   #11
ecp
Cam cover off
I got the cam cover off and i’m not going to lie, it looks perfect in there. it’s got 124k so there’s a little bit of wear marks on the cams and lifters but nothing catastrophic. no metal in the oil. from what i can see of the lifters everything looks okay.
What are your thoughts? I’m leaning towards a broken spring at this point. Just as a recap the dealership said they could see one valve stuck open on what i’m assuming is cyl two, since that’s the one with zero compression. When i took the header off though it was very obvious cylinder one wasn’t firing either.
ecp is offline   Reply With Quote
