Old 06-12-2021, 02:55 PM   #18
911monty
911monty's Avatar
What is controlling your clamshell? Do you manually lift to raise or stow the top then close clamshell? I'm guessing you are not driving it with the motor. Two switches give feedback to the relay on where the top is. One switch controls the light on the dash, the lever switch on the drive motor located under the clamshell. When opening top you must hold the open button until the light goes out. The light goes out when the lever switch is fully depressed by the clamshell when closing. So after all that, Have someone depress the lever switch and see if the light goes out. If it does then tie wrap would be your friend.
