Old 06-10-2021, 04:38 AM   #20
986 Boxster
986 Boxster's Avatar
Originally Posted by bcrdukes View Post
I'm running H&R sport springs with the Koni Special Active shocks and have been for well over a year. I was running a pretty aggressive track-focused alignment but changed it back to near-factory specs because COVID cancelled all PCA DEs here.
Did you experience less body roll with the track focused alignment?
I got pretty much the same suspension set up that you have and I was looking to add an H&R rear sway bar, but after I had a track focused alignment done, after installing the suspension, most of the body roll, if not all is gone now.
ike84 is right, the factory staggered set up of 205 front & 255 rear on these cars suck, I was experiencing a lot of understeer before I changed to 225`s at the front also. I mentioned that before on a thread on here and I am surprised that none of the track gurus pointed to the width of the front tires as the cause of the understeer.
986 Boxster is offline   Reply With Quote
