Thread
Father's Day Gifts COVERED this Year! 15% OFF CoverKing, GRD Watches, & More!!
06-09-2021, 02:08 PM
2
Gianni at Pelican Parts
Administrator
10% OFF All Nextzett Products!
Nextzett was founded in 1936 and has a history of creating high quality polishes and detailing products.
Nextzett has your car covered! and now you can save 10%.
Use promo code
NEXT10
at checkout.
Click here for Nextzett Products!
25% OFF Schwaben 1/4" Drive 46-piece set!
This tool set is a great portable set of tools to take on the road with you.
Containing most common tools and sizes needed to DIY
Use promo code
TOOL25
at checkout to save.
Click Here for the Schwaben 1/4" Tool Set!
25% OFF Schwaben 5 Piece Trim Tool set!
This 5-piece trim tool set is designed to easily and safely remove trim panels, door panels, mouldings, adhesive backed logos without damaging the surface.
Use promo code
TOOL25
at checkout!
Click here for Schwaben 5-Piece Trim Tool Set!
25% OFF Schwaben Cooling System Air Purge Refill Tool!
The Schwaben Coolant Air Purge Tool is an universal tool which creates vacuum in the coolant system in order to ensure no air pockets when refilling your cooling system.
Use promo code
TOOL25
at checkout to save!
Click Here for Schwaben Cooling System Air Purge/Refill Tool.
25% OFF BavAuto Crankshaft Seal Removing/Installer Tool!
The perfect tool for removal and installation of the front crankshaft seal on BMW N55 engines.
Use promo code
TOOL25
at checkout
Click here for BavAuto Crankshaft Seal Tool!
Find More Posts by Gianni at Pelican Parts
