Old 06-03-2021, 08:31 PM   #2
CrisZenithBlue
CrisZenithBlue's Avatar
it's a few clips on the brackets on both sides that connect the clamshell to the chassis.
but you might be better off explaining what the issue is with your top so someone might help diagnose and recommend a fix. The only way i could imagine a clamshell being "stiff" is not having any grease on the rails it travels on moving up and down, which you can easily fix by just opening half way up and cleaning and greasing the rails.
CrisZenithBlue is offline   Reply With Quote
