Old 06-03-2021, 07:29 PM   #31
ike84
Originally Posted by akbaradeli View Post
This is just forward of the gas tank and has several plastic fuel-line connections running into it. Disconnect those lines using the flathead screwdriver. Unbolt the charcoal canister from the frame using a 3/8-inch ratchet and socket. Slide the canister out of the bracket and remove it from the vehicle.
Akbar, have you done this? The real question is what to do with the disconnected hoses.
Sent from my POCOPHONE F1 using Tapatalk
