Old 06-02-2021, 01:37 PM   #6
Jasper7821
Thank you very much for the two links, very helpful, and hopefully the subframe goes back in and all the holes line up. If not I'll use the ratchet strap. And the engine/tranni mounts were all changed last year.
I'll check the braces but not sure how to see if they're bent some, they're not flat.
I have replaced those on two cars. They weren't damaged as bad as yours, just minor cracks. From my observation, these are brittle and will break away in most cases before damaging the frame of the car. In your case, I would be sure to check the black brace that crosses between the engine and transmission and the diagonal braces on the bottom.
You may need the assistance of a ratchet strap to get everything aligned correctly for re-installation. This would be a great time to replace you engine and transmission mounts while you are in there.
Some posts that I remember:
http://986forum.com/forums/boxster-general-discussions/63145-aluminum-diagonal-brace.html
http://986forum.com/forums/diy-project-guides/63154-replacing-rear-suspension-bracket.html#post510170
Jasper7821 is offline   Reply With Quote
