Old 05-30-2021, 06:01 PM   #11
ecp
Curious why you think it's the injectors. From reading it looks like you have at least a wiring issue with the o2 sensor.
What sensor on the cylinder are you referring to?
do what JFP suggests. Very much doubt you have a bad cylinder as you would have more problems and noises if so.
To test the injectors the best thing to use is a NOID. It will tell you if an injector is getting power. You can also bench test each injector to see if they at least work, which I bet they all do.
coils and injectors are both getting power. i don’t know how two cylinders would both lose compression at the same time if that’s the case. and unfortunately it seems that way until i do a compression test.
ecp is offline   Reply With Quote
