Old 05-29-2021, 11:37 AM   #21
Rundtinden
Update
Checked for vaccum leaks and found a hole on the underside of the right rubber sleeve connecting the plenum to the right hand side intake manifold (as seen from behind the car) Will fit a new one ASAP. It was quite a big hole too. Can this explain the codes on the bank 1 cylinders?
Rundtinden is offline   Reply With Quote
