Old 05-28-2021, 08:07 PM   #1
Stl-986
Doubt it's a maf issue. Sounds like a vacuum leak. could be the hoses, connectors, plenum , check valve, aos, reservoir. if you can get a vac gauge you can hook it up to any of the vac. lines and see what you are getting. should be 12-18 in.
Since it's doing this after an engine swap it's also possible you dont have something hooked up right.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
