Old 05-27-2021, 03:30 AM   #2
CrisZenithBlue
CrisZenithBlue's Avatar
yes, look at the door jam, there are 2 ways to do adjustments. adjust(loosen, move, tighten) the latch and/or the catch.
or just leave it as is. I have a 2000 that does this and I have just dealt with it vs messing with getting things lined up.
Gave it the bump and opened on the first try, thank you sir! Now I gotta fiddle with it to see if I can adjust the latch/catch.
Most likely its the latch getting old, the catch itself seems fine and doesn't seem like it moved at all but ill probably fiddle with the catch itself as it would be easier to revert to the original position if I screw things up. I think.. we'll see how it goes!
CrisZenithBlue is offline   Reply With Quote
